? for the pro's, what exactly is the salt used in swcg hot tubs? sodium chloride yes or no and it should be pure? Would really like to know what i can use in my hot tub as opposed to "spa store" stuff they never have?
So i could use Sifto water conditioner salt like the 1 posted here could i not even if it is more course, i am really tired of the manufacture/store playing salt games. i want to do a water change before winter and having a hard time getting salt, so water softening salt i figured i could use and alot less pricey and readily accessible. Appoligize if it seems dumb not knowing but i have learned alot from TFP and appreciate the feedabck and learning tools.Plain salt. Can be pool salt, water softener salt, etc.
Crystal Plus Softener Salt - Sifto | Pestell NutritionBe sure it is plain. No magic additives. That one appears to have an additive.
What is the additive?Be sure it is plain. No magic additives. That one appears to have an additive.
It says it contains a “stain fighter”. So that’s either marketing term for salt or it’s some kind of additive. Look at the ingredients and make sure it’s 100% solid chloride.How about this 1, i can get this 2mrrw lots of this instore.
Pool Salt – Sifto | Pestell Nutrition
Ingredients look better
That is plain. I would use the pool salt. You need about 10 lbs to get to 3400 ppm.Ingredients look better
Might be some iron stuff. Not enough to worry in your situation.It says it contains a “stain fighter”.
Yes it is, went and got the sifto pool salt instead 99.75-99.92 sodium chloride looked pretty good as far as no additives and 10$ for 44lbs should do the trick for awhile. I was trying to quiz them at the spa/pool store but they would not answer my ?,s hmnn. Only said if you use any other salt you will void your warranty lol. I said well if you have no salt there has to other ones you can use with swcg you cannot be proprietary otherwise people cannot use there spas and must shut off there swcg and manually dose it, thats not the idea i paid for. I live in Canada and like to use my spa very much in winter, they still had no answers and were all crickets hmnn, arghhh:/.As this is a spa and you dump the water every few months, the additive may not be as big a deal as in a pool.
They wouldn’t know. The warranties are mostly a scam. If they can’t find a reason to not fix something they can just blame water chemistry.Yes it is, went and got the sifto pool salt instead 99.75-99.92 sodium chloride looked pretty good as far as no additives and 10$ for 44lbs should do the trick for awhile. I was trying to quiz them at the spa/pool store but they would not answer my ?,s hmnn. Only said if you use any other salt you will void your warranty lol. I said well if you have no salt there has to other ones you can use with swcg you cannot be proprietary otherwise people cannot use there spas and must shut off there swcg and manually dose it, thats not the idea i paid for. I live in Canada and like to use my spa very much in winter, they still had no answers and were all crickets hmnn, arghhh:/.
PS; i would really like to know how in the heck they would know what kind of salt i used, as they will not be submitting water tests to some expensive lab for analysis.
My HT specs recommend 2200, I typically use 6lbs per refill and it stays stable. With no other chems added and not harsh. I looked at spa store salt and Sifto 1 and could see no difference what so ever, even ground the same coarseness. Tired of peeps playing games. Thank you very much TFP, Pro,s.That is plain. I would use the pool salt. You need about 10 lbs to get to 3400 ppm.
Great. Normal SWCG's need mid 3000's.My HT specs recommend 2200,
The spec table states to strive for min 2200, maybe I should bump it up some. Salt cell is keeping up with 2 of us though with what ii have it set at. Each 1/2 LB will increase it by 190. What's your thoughts?Great. Normal SWCG's need mid 3000's.
Glad it is working
