Here is my problem, I have been without a pump for over 3 weeks now and it looks like it will be Friday or next week before I can get it up and running. I have been keeping it as clean as I can by skimming and running my Dolphin A30i. The chemical balance as well as possible, adding LC when needed. I maintain a little flow inside the pool, by using my pool cover pump fully submerged, so at least it's not totally stagnet but it's only enough to mix up the chemicals a little. My current readings are FC 6, PH 7.4, TA 90, CH 225 and CYA 50. This is about as good as I can do without a pump but the water is starting to get cloudy. My question is when I finally get the pool people out to replace my pump, what procedures do you guys recommend? I want to get it cleaned up and balanced so I can shut it down for the winter. Any recommendations?
