I never know what size cover to get for our 25ft round above ground. Is there actually a correct size? What should I be shopping for? They only last a year or two before the grommets tear out anyway. Maybe I'm doing something wrong.
You want to have sufficient material to hang over the top rails & be secured by the cable & enough material for it to lay on top of the water after the water has been lowered. Most will tell you how big around the cover actually is. Here’s what the description for my 33’ round cover says. It’s plenty of material to do as I described.
