Okay so I got my volleyball stuff from
http://volleyballusa.com/Catalog/Nets/P ... yball.html
I got the stainless steel sleeves, caps and poles (seriously heavy duty) and a net (it was a custom length and i upgraded to included dowels and kevlar ropes, not sure if that is still an option).
So when i got everything in, i unpacked it all and starting examining it. Both ends of the sleeves had been cut at a slight angle, at first i was like what's this, then it dawned on me...my concrete by the pool would be finished to drain away from the pool, so with these sleeves stuck in the concrete perfectly plumb the top would be angled and match the concrete.....well when i asked about that they were like no, when we cut them the saw blade gets off line cause the steels hard to cut....so then i started playing around with them inserting the poles into the sleeves and noticed the gap, meaning when the net was pulled tight, if sleeves were installed straight up and down the poles would lean in. So if figured out the angle the sleeves needed to be installed to allow for a tight net and perfectly straight poles, explained that to concrete guy and all is well ( i thought of other solutions you could easily just wrap duct tape around the bottom of the pole to get a snugger fit, or get some stainless shims)
The net also had several little tears in the material that goes around the perimeter, looked like when sewing it it got caught up in the machine or something. I called and talked to them, since it was a "custom" length they didn't want it back and sent me a replacement. I was extremely happy, replacement was perfect, and the original was fine for use as the tears were just cosmetic. When installed the net is serious business, you can hang on it, whatever you want you won't hurt it. They are a family business that love volleyball, when you call and talk you'll get someone who plays and can recommend what is best for your situation.
Picks of tears in the net, i am extremely picky but i thought a replacement was justified, replacement was perfect.
Picks of it installed, thought i had better pictures sorry
I figured out a cleaner way to rig it too so it's fast to put up and doesn't have a bunch of strings/cords that need to be tied up every time. It takes me about 4 full mins. to install it, for me it takes two people to unroll it and then walk it to the sleeves with net stretched out over the pool, easier than re-rigging it up to the poles every time.
I would buy it again.
