Helping a friend w/ a pool at a new house. I brought my Taylor kit over and my water has always stayed between 7-8 pH range, always readable just using R-0004. But his water is dark red after R-0004 (44ml sample), looks darker than the red for a pH of 8. pH meter reports the water at about 8.5 (not sure how well calibrated it was). So I thought I'd try using some acid reagent (R-0005) into the 44ml sample.....3 drops of R-0005 brought the sample color down to 7.6. I don't use this reagent myself so looked up to see what each drop correlated to (for example does 1 drop of R-0005 reduce pH by 0.2-or something like that)...but the Taylor instructions just takes me to an acid demand table to show how much acid would be needed to drop pool into desired pH range based on pool size and the # of drops needed-(which is great we will need that info-but I was hoping to figure out what the current actual pH of his water is based on the fact that 3 drops of the acid reagent brought it down to 7.6-can I use the test to make that determination? For example if each drop does drop pH by 0.2 and 3 drops brought it down to 7.6 we would know his fill water is 8.2-but I don't see that type of correlation listed for that test.
Thanks
Thanks
