It is small, cheap and efficient and it will not be my primary heat source. It is rated for 13k gallons and my pool is 20k. But, we are in Texas so it seems like that makes it easier for the heat pump. We also have solar panels. And we have no desire to use it if daytime temps aren't in the mid 80s which puts night temps in the mid 60s. So, the heat pump will be very efficient. Part of my dilemma on getting a heat pump is the initial cost plus operating cost vs installing more solar panels. This heat pump is 1500 bucks vs at least 2500 bucks for the bigger ones. The main drawback of installing more solar panels is that they would have to be in a different location (probably on house) from the existing panels because that roof is full. Here are my pros on why this small heat pump is better than more solar panels. There have been a lot of days in spring and fall where the solar panels didn't quite get us there and 5ish more degrees would have made it good. We can heat the pool when it is cloudy or rainy. Most of the time the solar panels get the temp up so the temp differential for the heat pump is normally small. Now that I am paying for heat I'm more likely to use a solar cover. The operating current is 2.68 amps, so even if it runs 4 or 5 hours a day it will only cost about 10 bucks/mo to run it. We swim every day so maintaining temp is the goal, not spot heating.
