Hi
I've Googled this and read the manual and still have a question on chlorine. I understand on paper how to adjust flow and check salt levels using the Pentair Intellichlor Chlorine generator, but I can't find in the manual or on YouTube how to check and control the chlorine level.
First though,
I have an 18000 gal pool with Pentair variable speed plus solar touch. Now getting around to hooking up the chlorinator. I've been doing the chemicals myself for the past year.
So,
I added 7 bags of salt per Leslie's analysis and will double check with another water check before turning on the system. Do I have to wait 24 hours for the salt to dissolve completely?
When I'm ready, I power everything off, plug the system in, and power on.
I check the salt level indicator for green. Check status, green.
Then I adjust the sanitizer output either 20% on up or 2% on up. I guess I start with 20%?
How am I deciding what number to select for sanitizer output? I usually test with a Taylor basic kit and shoot for 2-4 ppm chlorine/br , a good solid yellow.
Do I start the chlorinator up, and after a while test with the kit, and if it's too high, turn it down, too low turn it up?
I live in San Diego, pump runs from 10 AM to 4 PM.
Thanks for any info, I must be missing something
Jeff
First though,
So,
Jeff
