**Update** Pressure test passing due to pipes running underneath home?
Thanks for all the responses. I think we might have found the possible leak.
On the spillover from the spa to the pool there are a few cracks. Any suggestions on the best way to repair the connection between the tile and pool wall at the spill over? Putty, grout, silicone?
You can see the cracking in the 2nd photo
Thanks for the suggestion.
Any opinions on EZ Patch 4 Fast Set vs regular? I have a tub of Regular but missing the tube of latex bonder it needs.
Also, wanted to clarify, fill these gaps with the E-Z Patch grout correct?
No need for Fast set. Fast Set is harder to work with. Turn off the spillover fir 24 hours and use the regular grout.
