I have a Vgreen Variable Speed motor model EVQ165.
Every third or so day the motor turns on (green solid light) but does NOT start running. Slight clicking noise and nothing. No fault light indication. Then, the other couple days, it turns on, starts running and primes then no air out of returns in pool, in pump basket and runs as normal. I can't find a defining factor that indicates whether it will start running or not.
About a month ago I noticed a ton of air was coming out of returns on start up and pump wouldn't keep prime overnight. Found the filter release valve was leaking, so I replaced that. Then noticed some water coming out the back of the seal plate of the pump housing (WhisperFlo). Not between the seal plate and the main housing - it was from motor shaft down back of plate. So I replaced the gasket seal, lubed all O-rings, took whole thing apart and put back together. Lubed and sealed gasket with DAP silicone-latex sealant. Seemed to fix 95% of leak. There is still a noise that sounds like air when pump is off but it is definitely holding water longer. Small leak comes out occasionally (should I have used appropriate silicone? - maybe, might have to redo all of that. There is also a small chip in the impeller where the ceramic o-ring for the shaft seal is inserted - happened when trying to pry out previous seal - but it's on the outside and the seal is still flush). All this might be the issue as to why motor won't start.
BUT, here's the strange part. On the days the pump motor doesn't start turning, if I turn off the electricity to the motor and then turn on again, pump motor starts turning and priming right away. Also, when I was placing the motor back on after placing new seals in, it wouldn't turn. So I tested it when it was removed from pump housing several times, and each time I turned on the electricity it started without fail. When I'd turn it on attached, wouldn't start. I resorted to starting it while removed from the pump housing, running a hose through the basket to prime the system, and it kept the motor going while attaching it to the housing (I'm sure this is a big no-no). It kept running as I bolted it on, and then started every time when I manually turned electricity on after that.
Why would it not work when I attached it to the pump housing, but start every time when it was removed? Would it have anything to do with the mount angle? And if that's the case, why would it struggle when automatic timer comes on, but then not struggle when I then manually turn on.
I think I may have had two issues. First, the leaks. Then, the motor issue. Question is whether the motor issue is due to lack of prime (but then, again, why does motor start up perfectly when removed from housing or when manually turned on after initial failure), or its a control board/electricity issue (but why would the electricity change between the timer turning it "on" and my manual "on"). I use a Pentair Intellicenter to control pool.
Hope this all makes sense.
Any help very much appreciated before I call in a pool repair guy or manually take the whole thing apart again to try and figure it out.
Thank you!
Thank you!
