You don't need to backwash every day unless you know it needs backwashing. Next time you backwash, when you turn it back to filter, check the pressure gauge and get an accurate reading when the filter is clean. After that, keep checking your gauge. When the pressure goes up about 25%, backwash. For example, if your clean pressure reading is 8 psi, when the pressure goes up to about 10 psi, it's time to backwash. You should not have to backwash daily unless there's something going on in your pool - such as the algae bloom you have going on now. After you get that cleared up, you can go days without backwashing.
GC
