Just try to keep the garden hose away from the skimmer and main drain.
I would not put it on the step because any iron will tend to stain.
Thanks for all the help. I think I'll just leave work early and go home and work on it. Apparently the whole thing is too much for my husband to comprehend lol.After draining/ refilling Be sure to let the water circulate for a day/overnight before testing cya & salt.
Also, keep adequate fc in the water with liquid chlorine so your algae doesn’t get worse until you can do the SLAM Process
Our water table is very shallow. Just a few feet. Hoping for lots of rain and I’ll just keep draining with the hose and refilling. Husband does not want to get a submersible pump.What does your water cost? To lower it in small amounts with your pool pump will take many times more water than using a submersible pump and following the no drain exchange shown in the Wiki article linked above.
As you live in Florida, we assume a simple drain and refill is not viable due to shallow water tables. If you are absolutely confident there is no risk to your pool shell by draining, you can do that. But be sure.
I’m draining into an already brackish pond behind our house.Be careful where you put the other end of the hose …. Draining 0000s of gallons of water has to go somewhere unless you have a drain capable of taking it that you are allowed to use. I’ve seen a neighbor flood their yard/house not thinking it through before
Just have a plan for where all the water goes before you open the spigot
Soon to be a salt water pond.I’m draining into an already brackish pond behind our house.
It is shark week…Soon to be a salt water pond.
Watch for sharks
Joking, #1 rule for pool ownership is have fun
No sharks and we’ve yet to see a gator in our pond but the next street over had one.It is shark week…
We rented a vrbo in orlando with a pool to go to Disney & it was in sight of the neighborhood lake. There was a giant alligator in there. There was no fence just a screen cage for the pool I was nervous the whole vacation! This was also right after the gator incident with the little boy at Disney.No sharks and we’ve yet to see a gator in our pond but the next street over had one.
We have a fence but no pool cage. I’ve seen videos of gators climbing right over fences. That incident at Disney was so sad. I’ve seen a few gators in ponds in the neighborhood in person.We rented a vrbo in orlando with a pool to go to Disney & it was in sight of the neighborhood lake. There was a giant alligator in there. There was no fence just a screen cage for the pool I was nervous the whole vacation! This was also right after the gator incident with the little boy at Disney.
We spend a lot of time in hilton head and gators have killed a few folks usually they come after the pet and the owner tries to save them.We have a fence but no pool cage. I’ve seen videos of gators climbing right over fences. That incident at Disney was so sad. I’ve seen a few gators in ponds in the neighborhood in person.
