strategy400
124
Southern California
A section (middle) of our new pool dig is about a foot to 1.5 feet deeper than specified. What are our options. The excavator said something about slope and the pool cracking in half. The pool is 40 x 24.
Best option is to make the pool deeper. Is it vinyl or gunite? If it is fiberglass then you will have larger issues.
If the excavator is concerned about the slope to the deep end, then you need to discuss with the builder on appropriate slopes. Do you have room to make the pool larger?
I love your pool size, awesome! Not sure if structurally sound, but add layers of gunite to raise up or add 57 stone/crushed aggregate under gunite in that spot.
It will feel huge for a week and then just be normal. Very few people ever wish they had less pool after it was built. You may be one of them, but you'd be the slim minority.
Reactions: Gladius Nova
18” of Shotcrete (for a total of 24”) is one way to correct the depth but I would involve a steel engineering firm first to see if a second cage of rebar is required due to depth of the Shotcrete. Typically on floors it’s not but with a phone call you can confirm.
I took measurements tonight by drawing a string across the top of the forms on each side of the area in question. The worst case of depth was 86 inches from top of forms to dirt. I'm desiring 60 inches of finished depth. Plans show min 6 inch floor thickness. So then it would be 80. I'm assuming top of form is top of shell? So I can lose another 3 inches to get down to the water line? So 77. Inch of plaster... 76. I need 16 extra inches of shotcrete to get to 60. Does my theory have flaws? Will varying thickness cause structural issues?
The steel people are here today unexpectedly and the bench that wraps around the spa, that are maybe 6 feet off the floor, have no rebar inside them. Is that normal? They said it will be built with cement. The red line is approx the height of the bench. The arrow is where the rebar is.Screenshot_20220609-124044_RXCamView.jpg
Why do you want that area built up?
When I help someone with a build I tell them to measure everything to make sure it is how you want it. I tell them to add about 8" for the steel, shell, and plaster. 8" from floor to the middle of the skimmer opening for WATER depth. 8" for each side for a total of 16" from side to side or end to end.
Reactions: Staceyleah22
I want to be able to walk across the pool there without going blub blub
  • Haha
Reactions: kimkats
