today morning saw this leakage
socialvista99
Active member
May 15, 2023
34
San Jose California
pump was on, water to pull was on to refill the level, saw this leakage. no idea what could cause it? definitely temperature has dropped quite a bit in last 4-5 days if that can help give a cue
Likely need to rebuild the Jandy valve that is under the actuator. You can buy rebuild kits with all the orings, etc. Just be sure you get the proper one for your valve.
I suspect the leak is coming from the oring seals in the valve. Likely matters not what setting the valve is in.
You can remove the actuator and move the valve manually to see if there is a difference.
Get at least a seal kit before taking apart the actual valve.
I stalled on fixing my leaking Jandy for too long, kinda intimidated by the prospect. It turned out to be a very simple job. If it's not actually the cause of the leak, it will be eventually. You'll just be doing the job a bit sooner, and eliminating it as the leak source should it prove to be otherwise. All valves need this repair at some point, it's not wasted effort. EZPZ.
You need to get a plug or a slice of pvc pipe the next size up and cover that hole.
There should not be water on that side. Unless the plumbing loops back to that area somehow. Pictures shown don’t give a full picture.
I will try the first advise.
What do you want the picture of to get the water flow story right? I’m really happy to have such an awesome forum and folks like you to help and make the pool care really trouble free.
I got panicked this morning and called up pool maintenance company and they might quote me high to just fix these things
For water flow we have to be able to see the pipes in all areas. A general picture, or pictures, that can be zoomed in on helps.
Is the actuated valve for solar? That could be why there is water on the side with the hole.
Marty figured it out. Even if your solar valve is a proper solar-drain-down valve, it would only drain water out of your solar panels and solar plumbing to a level equal to the height of the solar valve. The pipe leading out of that valve to the panels (the one that is leaking) is always going to be full of water unless there is some sort of manual drain on that side and you manually empty it.
If it's not a solar-drain-down valve, then that pipe is going to be full of water all the up to the roof, and probably keep your panels full of water as well.
When the plumbing is elevated that far above the pad with little support, any vibrations due to the pump and/or water hammer are amplified at locations furthest from the support. So over time, these joints are more likely to fail due to stress fractures especially that joint which is furthest away from any support. I suspect you can probably move that 90 a good distance without much resistance.
If you are going to replumb, I would drop the height of all that plumbing even if you need to add a few 90s on the heater.
Reactions: Dirk
If that heater is dead and never to be resurrected, you should just remove its plumbing while you're at it. It's only costing you increased pump RPM for nothing. Your SWG needs a minimum flow to fire up, which means a minimum RPM on the pump. It's virtually a guarantee that RPM is higher than it needs to be because of the water diverting through that heater and those skinny metal pipes. It looks like the return pipe to the pool is much larger, 1.5" or 2". That heater setup is nothing but a giant restrictor if you're not using it.
Reactions: newdude and mas985
but why is water being sent to the right side of candy, even when its in OFF state :|
Look at the diverter inside the valve. That may be a "solar" valve that has either a bad check valve or was made into a "solar" valve by drilling a small hole in the diverter.
That was a very common practice for a while (may still be) when an actual "solar" valve wasn't available. They were difficult to obtain without purchasing an entire solar-control kit. It is easier to maintain a supply of regular valves and just drill the diverter through an open port than have two separate types of valve on hand.
With the proper check and isolation valves in the system just drilling a hole never caused a problem during Winter.
Reactions: Dirk
