I'm going to do one tonight just to make sure I am in the clear, it was good 3 nights or so ago and I haven't done it since but I will.
Yes that sounds like metals. Most likely you will need a metal sequestrant to put the metals back into solution (take the tinting out of the water). See this link for recommended sequestrants: http://www.troublefreepool.com/pool-school/metal stainsJill said:Cool. I am pretty sure it's our hose water giving the pool the funky color bc now that it is filled up again the color is back to the yellowish/greenish tinge.
I think we are assuming you are algae free at this point so yes, I would let it drop down to the 3-7 ppm range (but never lower than 3 while your at 40 ppm cya).Jill said:I have to wait for my FC to go down to figure this out right?
I wouldn't at this point, let's work with the cloudy water first.Jill said:CYA:40 (should I raise this?)
If the stuff is on the bottom, I would vacuum it to waste if you can.Jill said:But on a plus side, dh threw in some Sea Klear PRS yesterday and I have to say, the bottom is covered with the beige junk and the pool is more clear except for the yellow tinge is still there.
