Temporary plaster crack repair
Sbp003
23
Leander, TX
Hello. My pool is currently impacted/ cracking due to ASR, currently the biggest source of water leak has been via cracked skimmers that I have temporarily patched.
However, I also do have a couple of areas on my plaster that are cracking and wanted to know the best way to temporarily patch those cracks, see picture. These cracks are not leaking water just yet, confirmed via dye test, but wanted to patch it up from an asthetical perspective.
What is the best product to use for this?
Epoxybond Pool Putty​
EPOXYBOND POOL PUTTY is a unique two-part, hand-moldable epoxy putty specially formulated for concrete or Gunite pool repairs. The convenient cartridge form provides a simple, equal mixing ratio (1 to 1).
Just cut, mix and fix. There is no need to drain pools to repair leaks and cracks because EPOXYBOND POOL PUTTY hardens under water. Once cured, it will not shrink or sag.
Color: White or Black (14 oz. Set)
Typical Applications:
  • Stop leaks
  • Fill cracks
  • Restore chipped tile
  • No need to drain pools…Cures under water
  • Simple 1-to-1 mix/Cut – Mix – Fix
  • Will not yellow, shrink or sag.
