Water looks very good. So I need to start using the liquid chlorine. Due to evaporation (high temps and humidity) adding water frequently
My take from that is he believes that he could potentially have had an FC of 3 with perhaps 250 CYA and prevent algae. I am thinking that since dkbrat's pool is currently clear it is probably low on nutrients, and thus with the polyquat can probably run around 10 FC with 360 CYA and manage to get by until a source of water can be obtained.chem geek said:I can tell you from personal experience that Polyquat will not completely prevent algae growth, but it will slow it down. In my own pool 9 years ago, I was using Polyquat but only dosing every other week (one is supposed to dose every week because it breaks down from chlorine and can also get filtered out if water is dirty since it is a weak clarifier) and had algae start to grow faster than chlorine could kill it with 3 ppm FC and 150 ppm CYA. Had I used the Polyquat weekly, then I speculate I could have had the CYA get to perhaps 250 ppm but I don't believe that Polyquat alone would prevent algae growth when algae nutrient levels (phosphates, nitrates) are high.
