imrodee said:sample was 25 ml of pool water
added 2 level scoops of 870 powder
sample turned pink
it took 8 drops of R871 x .5 = 4.0 FC
added 5 drops 0003 to turn it light pink
5 drops x .5 = .25 CC
FC + CC = 4.25
A quick mistake in the test. When using the test with 25ml you will multiply the number of drops by 0.2.....soooo 5 drops x 0.2=CC of 1
Don't mess with using 25ml of water for this. It's FAR more accurate, but uses more reagent. Only 10ml of water is just fine. The same result will be acheived with only 2 drops....that took you 5.
imrodee said:25 ml sample pool water
2 drops 0007
5 drops of 0008 water turned hot pink (not green)
instructions said to drop 0009 until sample turns red, x 10. Well, it was already red.
So TA = 0 I guess..?
Thank you..
Your TA and PH are VERY low. I would assume your PH is 6.8 (it could be much lower) and add something to bring it up to 7.5. I would assume baking soda in the case would be best, but I'm going to let others chime in. Let the pump run for about 15 minutes....then retest. Make sure you change your TA reading to zero in the pool calculator to avoid over-shooting your PH level. These two play hand in hand. I don't have much idea on raising your TA level......but I do know your best bet is to do it in steps. Your PH is going to jump all over the place for the next few weeks....so don't be concerned.
