For those of you who experience extended periods of extreme summer heat and water loss due to evaporation, when it comes to regularly topping your water levels off and maintaining chemistry...what does that process entail? If you add water every few days or every week, do you typically do the filling with the pump running and then test for chlorine levels using something like the OTO test or perhaps the FAS-DPD. Would you wait a while after adding water before running tests?
Thanks for the advice?
