Hello,
First, I wanted to say thank you for the wealth of information!
I have read here for a while and haven't had the need to ask for help yet but stumped with a mild algae problem that keeps coming back.
I have a 14,5000 gallon plaster pool about 6 months old using liquid CL. Followed levels recommended on the pool math app. I'm in SW Florida.
Pump is run for 12 hours daily at 45GPM flow rate.
Water Temp is 80F right now and I keep the chemicals at these levels:
CYA 40.
FC 4 - 6. (Never seen CC past .5 and 0 right now)
TA 60
PH 7.6 (Have to add acid daily due to new plaster)
CH 350
Phosphates 0
Copper .2ppm
I'm using TF-Pro test kit and test daily with the DPD Powder. I never let FC drop below 4 and am adding 20-36 oz daily of Chlorine.
Pool is brushed weekly and vacuumed every 3 - 4 weeks. It's under a screened enclosure and doesn't get much debris the skimmer can't handle. I use a skimmer sock and clean the filter every 3 - 4 weeks when vacuuming.
I use RO water to add water to it now since no rain here.
A few months ago I put a solar cover on the pool that stayed on for about a month. I never removed it but opened up a corner to check chemicals daily. When I finally removed it I was surprised with patches of green algae all over the bottom of the pool.
I followed SLAM for a week, at that time my CYA was 30 and I kept FC at 12 for about 4 days at which point the water was clear. The CC was never past .5 and the FC never dropped more than .5 overnight even with the algae.
I put the cover back on and two weeks later had the same problem again. Followed SLAM again and never used the cover after that.
Ever since then I get mild green Algae that keeps coming back, it's like the gift that keeps on giving. Currently running SLAM now with FC at 16.
I know CYA/FC chart says 5-7 for my levels and I try to keep it at 5 minimum but would a day of dropping to 4 for example really cause the algae to come back so quickly?
I attached some pictures of the algae and aside from that my water is crystal clear and FC does not drop overnight. I don't like the idea of high FC levels on a new plaster pool...
Thank you!
CYA 40.
TA 60
CH 350
Phosphates 0
Copper .2ppm
Thank you!
