I lowered my pH to 7.0 in order to lower TA in preparation for adding borates, but it is refusing to come back up into range. It's been stuck at 7.2 for several days. I suspect this cheesy fountain I bought on Amazon is just not cutting it. How best to get this aeration going?
The more “air” it gets the better it will work. Try pointing it up more so its more broadcast over the pool. The more it moves the water the better.
It can take days or even a week to raise ph several points in a pool.
If you have other jets also point them upwards so they disturb the water.
The TA is currently at 80, although I'm new to these tests so I am not sure if I'm measuring it correctly.
It's probably worth mentioning that the main drain was capped off years ago due to leaks so even at max RPM and a clean filter, we don't get a lot of water movement.
