Okay, let's fix your pool.
10 gallons of bleach would have been about a 40 ppm dose and possibly could've turned your liner white. Test and dose carefully and understand the outcome.
Now, I will be very blunt but it is to help you understand what you need to do. It doesn't sound like you have grasped the overall concept.
You must bring your FC back up to 15 ppm each time you test and CONTINUE TO DO SO until your FC loses less than 1 ppm overnight. Simply put, you have not been doing that and you are only prolonging your situation. Several people have referred you to the shock process but you have not been following it. Giving up because your FC drops more than you want it to is the opposite of what you are trying to accomplish.
Test and replenish to 15 ppm. Test and replenish to 15 ppm. Test and replenish to 15 ppm.
At some point the chlorine will begin to hold better and better in your pool and your dosages will get smaller and smaller. Until that time, you must continue this process regardless of how much chlorine it takes.
You must control your dosages in a uniform manner so you don't damage your pool.
Don't get sidetracked with peripheral issues and don't lose focus of what this process is all about.....Test and replenish to 15 ppm.
