- Aug 6, 2018
- 53
- Fiberglass
- Pentair Intellichlor IC-20
I've this pool since new, about 10 years but I'm still learning. I have at least 3 issues noted below.
Over the years, the walls have gotten significantly stained white. I have no idea next steps with this. It's not bad looking when full (until some evaporation occurs). I can actually feel that the surface is pitted. What can I do?
Also just under the coping you'll see dark stains, again very ugly.
Lastly is that there is one very tiny copper color spot, if memory serves, this is also pitted.
I only ever use bleach to slam which is done rarely.
The trees in the neighborhood are getting larger and I seem to be down wind of maple, oak and some huge flowering tree. My filters were changed last year, if any of this helps. My IC20 is dying / dead I think and I'm using liquid chlorine till I resolve that issue. My salt is still about 2600 so I assume I should bring that up before ruling out the cell.
The pool store says I have no iron but .3 - .5 ppm copper depending on the one I go to. Phosphates were last about 15.
Thanks for the help
Thanks for the help
