I have an in-ground pool with attached spa which spills over to main pool. The spa has 2 bottom drain openings and 2 side drain openings located about 12" above spa bottom. Both side drain openings have curved grills to reduce entrapment risk. There is a single 2" return also located about 12" from bottom. Multiple spa jets are arranged at the typical level, maybe 36" from spa bottom. The spa has a separate jet pump.
As currently configured the jet pump circuit has suction connected to the bottom drain and returns to the waist-level jets. The main circulating pump draws from the SIDE drains and returns to the single 2" side outlet. I believe this is plumbed incorrectly, as the dirt and sand which settles to the bottom doesn't get drawn through the filter, as the only filter is on the main circuit. Also, when the jet pump is used it is blowing the dirt near the bottom right back at the bather. This is not necessarily noticeable, I just realize it must be happening!
So this all sounds wrong to me, and I am just wondering it there is any logical reason to keep things as they are before I replumb the thing!
