Attached spa water level has been dropping to pool level overnight. Replaced check valve thinking it was the culprit but level still dropped as before.
What’s next?
What’s next?
What’s next?
Here ya go:I would recommend posting a pic of your spa and also the equipment pad so viewers can see what you have there. I might help put everything into perspective.
New check valve was put back just like the old one and o ring coated with Magic Lube. When pump turns off at 4 pm water level is just below spillway on spa and down to pool level in the morning.I'd like @Jimrahbe to see this thread. Pad looks fairly straight-forward and if the valve is operating properly (brand new) it should be working as long as it was installed in the correct direction. Hopefully it's not an issue at the spa drain itself. About how much water drop are you seeing?
I think i found the culprit responsible for my leak. Found this twig in the intake valve while I was replacing all the o rings.Thanks for everyone’s input. Looks like it’s time to rebuild the valves.
My question is how does a 3 inch twig get past all the filters?I think i found the culprit responsible for my leak. Found this twig in the intake valve while I was replacing all the o rings.
Opened May 2006B,
Impossible I'd say...
How old is the pool?
Me primarily. I’ve used same pool guy that built pool for stuff outta my league.Are you the only one performing maintenance or do you have a pool service?
