All was good until I had to have 23 feet of crack repaired in the pool. Drained, repaired, total replaster and filled. After filling found I had developed a leak around the skimmer where plastic meets tile. Used pool patch to ‘fix’ that. However, aflyer plaster and fill, my spa level will drop overnight. I’ve used dye to look for a leak around the drains, jets and spillways. Finding none, I bought and replaced the Jandy check valve ( just the flapper, not the whole valve). Had issue several years ago and flapper replacement was the fix. Still drawing down overnight. Level drops to the same level as the pool water.
Any ideas from the “august” group?
Thanks in advance
Thanks in advance
