We’re glad you found us! Let’s turn this around!
A couple notes to help you & help us help you…
*Update your signature with all the info you can about your pool, your exact test kit, your pool cleaner etc. - see mine at the bottom of each post as an example (turn mobile devices sideways)
www.google.com
*Use
PoolMath to calculate all additions- also, the subscription ($7/yr) is definitely worthwhile as it allows you to keep logs of all your test results & additions (amongst other things) as well as share them with us (if you click my avatar you will see mine). It also allows for you to do this for multiple pools if you also have a spa or vacation home pool.
*For a successful SLAM Process
you need to continue to
MAINTAIN Slam level fc for your cya
FC/CYA Levels
as often as possible (multiple times per day is best- every few hours if you can swing it) until you meet ALL 3 end of slam criteria-
You are done when:
CC is 0.5 or lower;
You pass an Overnight Chlorine Loss Test
AND
the water is clear.
(Crystal Clear w/no algae dead or alive)
*Check & scrub every nook & cranny where algae may hide (light niches, steps, drain covers, ladder handrails, skimmer throats/weirs, etc.) if water can go there algae can live there
*Run slam level water through all water features & lines for at least a couple hours a day during the
SLAM Process.
*Brush & or vac daily (this breaks up biofilms that algae uses to protect itself from chlorine)
*Backwash/clean filter when pressure rises 25%over clean pressure.
SLAM ON! We got u!
