Hello experts -
Second year of owning pool, first year of performing an official "opening". Apologies for the lengthy post, but want to give clear info.
I'm following the SLAM method in an effort to get to the recommended SLAM FC level of 12:
Started 5/10 p.m.
Initial pH: 7.5
CYA: 0
FC: 0
Added 5lb stabilizer
Got CYA up to the recommended level of 30 and that level has maintained at each testing.
5/10 9:00 p.m.
Added 6gal 6% liquid chlorine
5/11 7:30 a.m.
FC: 0.5
Added 4gal 6% liquid chlorine
5/11 10:30 a.m.
FC: 0.5
Added 6 gal 7.5% liquid chlorine
5/11 1:30 p.m.
FC: 1.5
Added 5gal 7.5% liquid chlorine
5/11 4/30 p.m.
FC: 1.0
Added 6gal 7.5% liquid chlorine
If i understand correctly, it would be expected for the FC to dip as reflected in the 4:30p.m. test given super sunny here today. However, my question is:
Am I doing something wrong - i.e., should i continue to be patient and slow and steady in adding the recommended incremental bleach amoutns at each testing, or will doing so never get it to the recommended level of 12? OR, should i go nuclear and add a metric sh*t ton of bleach to try and hit 12 and maintain it until overnight chlorine loss tests show a stable level? Fear I'm wasting time and $$ by adding roughly 6 gallons at each timing with very minimal increase in the FC results. Side note - the water is definitely getting clearer.
Any advice is greatly appreciated!
Started 5/10 p.m.
Initial pH: 7.5
CYA: 0
FC: 0
5/10 9:00 p.m.
5/11 7:30 a.m.
FC: 0.5
5/11 10:30 a.m.
FC: 0.5
5/11 1:30 p.m.
FC: 1.5
5/11 4/30 p.m.
FC: 1.0
