Hi there,
I had a big algae bloom due to getting a water feature fixed and overflow from the water feature into the pool.
I'm now in day 4 of the slam process and the water is still very hazy. Aside from running the pool pump 24/7, I have been testing chemicals daily, vacuuming with the robot, brushing, and skimming.
Chemicals:
FC: 5
PH: 7.2
CYA: 50
TA: 100
Overnight FC loss was about 3 PPM.
What are the thoughts? Do I just need to keep running the pump 24/7? Alternatively, I run the filter daily for 8 hours. Is the only way to clear this up by running the pump continuously?
Thank you,
Chemicals:
FC: 5
PH: 7.2
CYA: 50
TA: 100
Thank you,
