Hi
I had algae but pool has been clear: I started SLAM now my CC is high.
PH 7.2
CYA 75
FC 15
CC 2.2
ALk 80
Since my CYA/FC are at SLAM level and I have not met the SLAM finish requirement with the high CC: do I just keep running the pump 24hrs to lower the CC? Do I add more liquid chlorine?
Also I used the CYA/FC level for shock found in the salt pool table but when I use pool math for the FC level it says FC 15 current and SLAM 31 and target is outside of recommended range? Why is that?
Thanks for you help!
PH 7.2
CYA 75
FC 15
CC 2.2
ALk 80
