Is the water cloudy or its just the sediment?
Using large amounts of cal hypo can certainly cause cloudiness, so can algae.
Your ch (if that is a correct result) is high enough & cal hypo should be discontinued.
It is not recommended for daily chlorination.
Before chlorinating your pool, you should know these simple tips. Learn the best way to add chlorine to your pool.
www.google.com
Sand filters are designed to work best with sand although not sure if that’s your current issue.
But if you’re planning on inspecting it anyway its a good time to just go back to sand. You can always add a little DE to the sand to help catch smaller particles.
Leslie’s idea of recommended chemicals & levels varies greatly from ours as they are in the business of selling you products. Their “free” testing isn’t really free.
Use our tool to find ideal chemical levels for any swimming pool. Check TFP recommended levels on pH, free chlorine, cyanuric acid, and more.
www.troublefreepool.com
FC/CYA Levels
Which should I buy? TFP's recommended pool chemicals are cheap, easy, and won't unbalance your pool water.
www.google.com
These pool chemicals should not be added to your pool. Save your money and frustration and avoid these chemicals!
www.google.com
The first step to getting your pool in order is getting your own reliable test kit that you can use frequently
Taylor k2006c or tf100/pro
Also pool store test results are fraught with inconsistencies (especially cya) and your pool chemistry should be monitored on a frequent basis (more than once a week).
This also gets you off if the “reactive” cycle & on to the proactive way of caring for your pool.
Until you have one of the recommended kits in hand you should add 5ppm worth of liquid chlorine to the pool each day. Nothing else.
What are the “recommended” things that you have already added?
How are you currently chlorinating?
Liquid chlorine/Trichlor/dichlor/cal hypo?
*Note*
A bigger problem is Your copper level is quite high - (metals are the only test we recommend getting at the pool store- not because they are the most accurate but because home testing for them is expensive)
does anyone at your house have green hair/fingernails?
Got stains?
Discolored water after adding chlorine?
you should discontinue use of copper containing products immediately & need to exchange almost all your water to get the copper level down to 0.3ppm or less.
See the no drain water exchange
www.google.com
You can attempt to use sequestrants to “hide” the copper but it will be quite expensive (they must be replenished) and they also have the side effect of clouding the water when used in large amounts. Also, Sequestrants can also only do so much - the solution for pollution is dilution!
