GREAT!!!
First, when doing the CYA testing, we only measure at the lines. Fill to a line, look, still a dot, look to the next line. Your CYA is 80.
Assuming you still have a swamp...
At a CYA of 80, you can try to slam, but may be a challenge. Usually more difficult when CYA is above 60. However, you have a small pool at 6800 gallons and it may be ok. Decision is a toss up.
Either A) replace about 2-3000 gallons first, then slam, or 2) take your chances and slam at 80. Slamming at 80 may take longer, or not work, then you will be forced to replace some water to get the CYA level down to be able to SLAM.
Follow the SLAM process LINK -->
SLAM Process
You will need muriatic acid to reduce your pH, and a bunch of liquid chlorine for the slam. I'd get 8-10 gallons to start.
If you decide to replace water, look for "no drain exchange" in this article:
www.troublefreepool.com
