From other posts here, it sounds like this pump is the way to go. I'm evaluating both the 011056, and the 011075 with or without added touchscreen option.
What price is reasonable for each, just parts? And approx what is reasonable installation labor cost on top of that? I'm bracing for massive markup from my pool company, as they recently quoted me $135 for a Jandy 2-port diverter valve, which I can buy for $65 on Amazon.
I have an iAqualink 2.0 control panel which is hooked up to my current main filter pump (and also to a Polaris pump, waterfall pump, pool lights). Will that suffice for a weekly pool technician to turn on / off the new pump, or is it important to have a touchscreen on the Intelliflo3 for them?
[EDIT: To clarify, I assume I can't use the iAqualink to program speed & flow on the new VS pump, that would be left to the pump's onboard touchscreen or mobile app if WiFi model. I was wondering if I had just WiFi but no onboard touchscreen, could a pool tech visiting when I'm not around still simply turn the pump on & off from the iAqualink?]
How usable / useful is the mobile app? Does pump automatically go to high speed to (re)gain prime if needed at startup, then drop down to its programmed setting?
Thanks!
[EDIT: Pool company quoted $135 for Jandy Pro Series 2-port while Amazon lists $65 for Jandy 2-port. Is there any real difference?]
Thanks!
