The videos are really helpful, thanks. Brian needs to have final say here, but I think that's pump cavitation and not something you want to allow to happen.
Good news is it only happens if I pull directly from that valve which is basically never. I do use it once in a while to vacuum with but even then I never adjust the valves enough for that to happen. While all the valves are open, if there's any cavitation or air at all it's not visible to the Eye. The basket is pure clean water unless I pull from that valve primarily. That said, there may still be enough air, even though I can't see it, to be causing me problems at the salt water generator I presume. The new cell is currently on and generating so it won't be long until I know. Scale begins to show up basically after the first day then accumulates the following days. I'm hoping the new cell makes a difference, if it does not I will shut that skimmer off completely and see what happens. I'm also still trying to get my TA to drop but it's being very stubborn currently still at 95 to 100. I say 95 to 100 because at nine drops it is just about to no change, the tenth drop has a slight change where before it was profound. Anyway once I get it down to 90 or below I will add borates as well. I just want to do one thing at a time so I can identify the problem, that is if I can identify the problem.
