I also bought a house with Aqualink automation and Pentaire equipment except for the SWG, which was Jandy AquaPure 1400. My pool is ~19k gal (near yours), but shaded, so chlorine lasts well. The SWG was broken, but replaced the sensors and it's been doing great for two full summers so far. Control with the Jandy app is easy and smooth.
The AquaPure cell has a reputation of dying early due to corrosion problems, but that hasn't happened to mine yet. I think it's 14 years old, but most of that was spent broken. Its chlorine output is also among the lowest of all brands.
Just to give you a feel for the numbers, the output is 1.25 lb chlorine in 24 hours at 100%. That's ~7.9 ppm for our pools. The pump must run for all the hours of generation. In mid-summer, I set it at 40% for 14 hours. That's 7.9*0.4*(14/24) = 1.8 ppm every day. Same as 1/3 gallons pool LC. So 2 gallons per week. About $60 per month at current prices. If your pool is in direct sun, you'll double or triple all that.
All that said, I will never buy a Jandy anything except minimal parts to keep what I have going. If the RS Aqualink box ever develops a serious problem, I'm switching to Pentaire. Why? Jandy was bought by a bigger company. Now it sells replacement parts for extortionate prices and disses DIYers at every turn with their warranty policy.
Good luck with the project! I'm glad you found a technology that helps with your condition. The experts (of which I am not one) here are terrific and helpful.
This whole operation runs on donations. Consider becoming a contributing member.
