Rusted, busted pump motor
zea3
14,659
Houston, Texas
My pump died over the winter. When I started taking it apart I found the shaft had rusted and "welded" the impeller to the shaft.
Any way to prevent this from happening on my new pump motor?
I drain the pump, then actually remove it from the outside plumbing it is connected to (I do put PVC caps to the pipes to keep the critters out over the winter). For draining - there are usually some bolts / screws you can undo to get the water out.
I do this because I actually cover and close my pool over the winter . If you live somewhere warm enough to keep the pump running all year - then by all means keep it open and pumping.
