So I replaced the motor on a Hayward max flo pump sp2807x10 because motor was getting louder. There were no apparent leaks before replacement. Motor was approx 6+ yrs old. Had weg 1hp replaced with century 1hp same model ust1102/56j.
I have replaced motor and seals before so I know seals were installed correctly.
Within a couple days there was a leak from the shaft seal dripping between mounting plate and motor face.
Replaced seals again but began leaking again.
Replaced impeller with new seals as a precaution for possible wear on the shaft same result.
Then reinstalled old motor with seal that was leaking on new motor and no leak was apparent after a couple days.
Last attempt reinstalled new motor with new seal and leaked after 3 days.
I considered shaft being bad but there is nothing apparent. See video below.
No leaks from housing seals.
I assume it's a bad motor but looks good to me.
PS I even tried a used spare seal plate/mounting bracket with the I had laying around with the new motor, no difference.
Video of running motor shaft
Any ideas? Thanks in advance.
