So I've just converted over to swg and had an RJ45+ installed (need to update signature). I waited 24 hours after adding initial salt and was reading 3400 using the 1766 kit. New vsp pump running 24/7.
The swg was generating first day with no issues. Second day I've noticed twice now that the water coming through the cylinder is clear instead if hazy. The wall mount showed 0 amps and 0 salt. Both times I turned off the swg and then turned it back on. It immediately recognized salt and started producing chlorine. The water exiting the cell was cloudy and the display shows amperage on the cell.
Thought I'd post here before calling circupool in case someone has experienced this before.
