- Jun 7, 2017
- 9,388
- Plaster
- Jandy Aquapure 1400
I just installed the CompuPool salt cell to replace my Jandy 1400 salt cell that died because of corroded power connections within the cell. Happy to report, the install was extremely easy as other have mentioned!
I did have a question if anyone is using the Jandy iAqualink automation with the CompuPool cell? The iAqualink app does not recognize the CompuPool Cell when I check status of the system or attempt to change AquaPure settings.
At the panel, everything looks good with no error codes. Shows good flow and producing chlorine, so I'm assuming the cell is working fine.
Anyone else having issues seeing the CompuPool cell within iAqualink?
thanks!
Did you hook up just the new cell to the old Aqualink 3 wire connections and are still using the AquaPure power supply? Can you post a pic?
