Hi all,
I have a Sta-rite Dyna-Glas series MPRA that had a pretty good leak. I replaced the shaft seal, diffuser seal and the seal plate o-ring with parts listed in my manual. Was perfect for a couple of days, but now has a very slight leak (about 1/2c) per 24 hour run time. Suggestions?
TIA
PS for those struggling with removing the impeller, I McGyvered a couple of pipe clamps together & put them around the outside of the impeller with a cloth under them to avoid ruining the impeller. My hands aren't big enough to get a good grip. The clamp screws give something to press against. Hope this helps someone else, as I wasted tons to time, not to mention the frustration.
TIA
