I am rebuilding the burner tray of my Raypak P-R406A-EN-C Heater. I purchased most of the parts, but there is no details on the pilot assembly. Does anyone have a picture or diagram. I believe I have the Honeywell IID Atmospheric Pilot.
Yes thank you. I purchased the whole assembly from Raypak, part number 002003F. But how does it connect to the burner manifold. The bracket assembly is not shown. I think because there are a few pilot options. Mine was so rusted it was unrecognizable. I purchased a few of the brackets but have no idea what is should look like.Is this the manual for your heater... http://cdn.globalimageserver.com/FetchDocument.aspx?ID=c404f1c5-ac50-4209-9457-56246d010b20. Figure 62 on page 34 shows a picture of the pilot assembly.
Which bracket. I purchased two. 010352F and 306692. Is there any diagram that shows the assembly?The bracket slides onto the notch on the right side and secured with the ground wire and screw in the front. The pilot is secured inside the square part of the bracket with a single screw. The spark should be facing up.
Thank you. Yes ive seen this burner refurbished on youtube but no good shots of the pilot assembly. Others are different burner types on different heater models. I'm not a pro so I just looking for more details. THANK YOU!Make sure the proper orifice is installed with the pilot. The pilot assembly should come with a small diagram picture.
