- Apr 26, 2021
- 65
- Vinyl
- Pentair iChlor 30
I just got done with a new pool renovation. Basically, all new equipment and plumbing. I went away once I got my chemicals set, and I probably increased my SWG too much. When I returned, I had to replace some water loss as well. However, I think I am in a better place albeit a little high pH (which I added some dry acid). I cannot tell if my Alkalinity is too high or if my CH is too low (based on different threads and pool math). To save words here, you can view my signature and profile for more of my pool information.
I have some questions about color changing. Are we looking for a color change at all (Green to pink), or a deep color change (Green to dark pink/red)? I have putting an extra drop to make sure the color change is complete (e.g., completely clear or completely red). I am loving the accuracy and consistency of my Taylor kit, but I am already running low on some reagents. I know I can cut some of the samples from 25ml to 10ml, but is it as simple of changing the multiplier (e.g., .2 to .5 for FC) and sometimes number of drops? As an example, should I still be using 2 full scoops of R-0870? Does it need to completely dissolve...even if I shake for a 30+ seconds, sometimes I can see tiny crystals settling at the bottom?
Any other advice on chemical testing would greatly be appreciated.
Test | 6/9/23 (Taylor) | 6/14/23 (Taylor) |
FCL | 13 | 9.6 |
CCL | 0 | .2 |
TCL | 13 | 9.8 |
pH | 7.7 | 7.8 |
Alk | 100 | 100 |
CH | 140 | 120 |
CYA | 80 | 70 |
Salt | 3800 | 3600 |
Iron/Copper/Phosphates | N/A | N/A |
