Our salt pool has developed a problem we've never seen before, INTEX POOL 12 X 24 X 52" deep, I installed a new salt cell this year from INTEX, it's supposed to handle up to a 15000 gallon pool, ours is about 9600, INTEX 22 or 2600 GPH sand filter pump. The titanium plates on the chlorinator side foul with calcium build-up in about 4 days and it causes cell shutdown and low salt indication, water chemistry is salt : about 2900ppm, calcium hardb=ness 300, chlorine runs about 1, PH I try to maintain at 7.6-7.8, our water as it comes from the pipe is around 300 calcium hardness and PH runs a solid 8.1. The solutions I find are to partially drain and refill, but it seems ludicrous to drain & refill with 300 ppm calcium hardness water, or am I missing something? I've never had the cell foul this quickly, usually takes about 3 weeks, any thoughts or solutions are greatly appreciated. Thanks in advance, Jeff
