@ss32000 tell us more about your vinyl safety cover. Is it an automatic one? Do you keep it open or closed most of the time? I'll assume it is opaque.
Last night I could actually see end to end underwater. It wasn't 100% crystal clear but a week or so ago the visibility was maybe half of that at best.
So on that point, when I'm checking things those areas what should I do? For example, if I find some brown stuff (assuming dead algae), should I just wipe it out or try to vacuum?Nice!
Be sure to check hidden areas for algae - inside the skimmer throat, back of the weir door / weir door foam, any light niches/ladders, etc.
Scrub it out into the water. It'll either die and settle to the bottom where it can be vacuumed up manually or with a robot or will find its way to your filter and get filtered out. The important thing is to scrub it out so it can be killed by the elevated chlorine in the water.So on that point, when I'm checking things those areas what should I do? For example, if I find some brown stuff (assuming dead algae), should I just wipe it out or try to vacuum?
I have done that and it does look good. I have to admit, my pool looks great, but I'm still failing the overnight test and I'm finding brown dead algae in the pool. It's ironic that the algae always settles in the bottom in the same spots, so it's easy to brush or vacuum up. I figured with my water starting really clear I'd be through this in a couple days, but I'm still in it.Check it at night with the pool lights on for the wow factor!
