- Jul 21, 2013
- 52,854
- Plaster
- Pentair Intellichlor IC-60
Yeah, setting the cams is a bit finicky. Just takes some patience and trial and error until you nail the setup.
So I can use the “manual method” to set all these?
You mean do that by hitting buttons on the control panel within configuration or you mean actual electrical connections?25,
I suspect your pool builder has the Intake valve connected to the "Return connection" inside your automation. And, your Return valve connected to the "Intake connection" inside your automation..
Not an issue unless you try to use the Spillover mode..
Swap the two connections and you should be good.
