Tested this AM:
FC 9.5
CC 1
CYA 0
PH 7 (actually looks like it could be below 7)
TA 50
I would add Borax to get me to a Ph of 7.2 and bring the FC back up to shock level. What do you guys think?
Remember, you are better at doing the CYA test than most pool stores.When I opened exactly one week ago I tested CYA and it was 0. I added 4lbs solid CYA. Added another 4lbs solid CYA on Friday so my levels should be 30-40ppm. I also suspected a higher CYA was responsible for the lack of FC loss, so I even took a water sample to the pool store and it tested 0. I know that the CYA I added won't register for at least a week, but I wanted to see if that 0 starting level was accurate...
Is there any possibility that the pool is more than 25,000 gallons? Less than 30 may not show up on a CYA test, so you may have it hiding just below levels that can be tested.
