Hi there! Our pool builder just installed the following equipment and I'm hoping to get some insight as to if this is better or worse than what we should have had installed?
It doesn't look like they included the WiFi antenna for the Waterway nor valve actuators. They should have installed the Waterway 770-1006-PSW2 kit that had all in the box. No point in having automation that doesn't do more than a mechanical time clock would. By itself the Oasis is more expensive than the IntelliConnect, with the whole kit it is more. It doesn't look like the builder is giving you what you are paying for.
Check valve will only help until it, too, is damaged by the highly corrosive solution that will occur. You don't know that it is happening until it is too late.
