So question about the IRC/ISPRC 311.3 "The water velocity in the return lines shall not exceed 8 feet per second". Does anyone have experience on the impacts of modern variable speed pumps and flow requirements. For example the Intelliflow XF supports up to 3" connections, but at a with modest head loss of 30' (actual design) at top rated speed 200gpm (~8.5 f/sec) would exceed the allowable flowrate for 3" plumbing. Going to 4" plumbing would solve this problem but the suction/return velocity at the pump would still exceed the maximum "Code Requirement" because of the connection size. Even the new Intelliflow 3 at full speed would exceed the 6 f/sec on the suction side.
It is fairly easy to control the flow rate at an individual suction or return but not as easy to control the maximum flow that is limited by the actual pump design connections. Considering that most pools are plumbed with 1 1/2" and 2" lines, Even using Pentair Intelliflow i1 with 45' of head can hit 90gpm (~9 f/sec) not sure how to interpret this.
It is kinda funny that the code requires the use of Variable Speed Flow pumps, but there are few VSF pumps on the market that will satisfy the code velocity requirements unless you have a bad hydraulic design. The code is pretty clear so I am not sure what I am missing here ....
Thanks!
Thanks!
