Hi all,
So I noticed a leak under my pump today. after quick research here I inspected the shaft seal. It was damaged/worn out.
Went to pool store for a replacement. Installed that. Let the pump run. It still leaked. Re-inspected the pump. The newly installed shaft seal broke! ?
Perhaps I got the wrong version but figured it's a good time to price put a replacement pump if in fact the one I have crapped out.
Which ones do you recommend?
My pool is a kidney bean, approx 17x30. Doesn't get deeper than 5.5 feet. And shallow end is about 3 feet. I think it's close to 18,000 gallons.
I have a sand filter Hayward s244t. Holds 300 pounds of sand.
Is there anything else I'm missing that would be helpful to provide a recommendation?
Thank you guys.
Thank you guys.
