- Dec 21, 2023
- 123
- Plaster
- Hayward Aqua Rite (T-15)
Hi so I am pretty new to maintaining my own pool. I did some vacuuming today and then turned the pool pump off. When I started the pump back up I opened the air valve on the filter first. However the pump basket isn't filling all the way up. Not sure what to do I did open the basket to clean it and put it back on tight. Could it be more air that needs to escape from the air valve? Should I just leave that open for a while. I dont feel there is much air coming out of there when I have it completely open though it is tough to tell as the water flies out.
When my contractor is here replacing stuff every time he turns the pool back on the pump basket is filled to the top. Just curious as to what I might be doing wrong. There is no way I have a leak as it was fine before I shut it down.
