In the process of getting my setup dailed in, last night, I noticed a "low flow" reading on the screen logic app when running at 1600 RPM.. In doing a little research on the IC40, it seems to need a 25gpm rate as the "minimum". which is about 1800 RPM in my setup.. at 1600 RPM (Inteiiflow VSF) I am getting between 16 and not registering, thus why I think it produced that.. I know plumbing, pipe size, etc. might vary the RPM/GPM, just wondering if that is variable all depending..
Also, I am noticing that at 1800 RPM, I am getting between 6-7 PSI, at 2000, between 8-9 PSI, and at 2500, about 12-13 PSI. when spillway runs, 2800 RPM at 18-19 PSI.. I don't know if that is normal or low from a PSI standpoint. Just did a backwash on the filter, and I got the same readings.. Also after running the backwash and returning the multi-way to "filter", when I started up the pump, I noticed that the filter handle was "loose" (up/down) and there was next to no water flow going thru the check valve after the heater.. I moved the handle left/right, back to filter, and then flow returned..
Could this be a gasket issue?
